Getting growing effect to random avoid areas and to spread less evenly
min_cheung12
Hello, I have a growing effect on some geometry with the solver, I need the growth to start from one point, which it does, however I need it to look less even and for it to have some random gaps as this effect will become ice with shaders. Any ideas, how I could do this?
I have attached the files too
Thank you!
Corridoor_3_Thickness.obj
Corridor_Ice_Spread_003.hipnc
You can add some randomness to the edges by replacing the constant in the Solver with a random number based upon the neighbors.
// Original.
float weight = 1.4 - smooth (0, radius, dist);
// New.
float weight = fit01(rand(nbr),0.7,1.4) - smooth (0, radius, dist);
To avoid areas, just delete points before submitting them to the solver.
ap_Corridor_Ice_Spread_003.hipnc
