ubcsdelta Posted March 11, 2018 Share Posted March 11, 2018 (edited) Greetings everyone. Struggling with setting up network rendering with Houdini 16.5. I use "use existing IFD" option and, unfortunately, can not use 'render current HIP file', because my hqclients running headless (nonGUI). Submitted jobs are failing with Warning: prepareIFDRender() got an unexpected parameter 'enable_checkpoints'. Traceback (most recent call last): File "/home/HQShared/houdini_distros/hfs.linux-x86_64/houdini/scripts/hqueue/hq_prepare_ifd_render.py", line 27, in <module> hqlib.callFunctionWithHQParms(hqlib.prepareIFDRender) File "/home/HQShared/houdini_distros/hfs16.5.405-linux-x86_64/houdini/scripts/hqueue/hqlib.py", line 1482, in callFunctionWithHQParms function.__name__, parm_name)) TypeError: prepareIFDRender() takes the parameter 'cross_platform_ifd' (not given) in log. Could please somebody explain how to set 'cross_platform_ifd' correctly. Thanks in advance. Edited March 11, 2018 by ubcsdelta Quote Link to comment Share on other sites More sharing options...
ubcsdelta Posted March 11, 2018 Author Share Posted March 11, 2018 (edited) Well, just a though... It seems that hq_render ROP returns hq_cross_platform_ifd while hqlib.py uses cross_platform_ifd everywhere. Hmmm... Do I need to edit hqlib.py and recompile to hqlib.pyc, or (hopefully) there's a better way? PS. Or am I completely off the track... BTW, can not see anything regarding cross platform rendering in HQPARMS section of Diagnostics information HQPARMS: { "frames_per_job": 1, "dirs_to_create": [], "project_name": "v_mantra", "frame_skip": 1.0, "start_frame": 1.0, "end_frame": 1.0, "max_hosts_per_job": 1, "min_hosts_per_job": 1, "ifd_path": "/Library/HQServer/HQShared/test/mantra.ifd", "render_frame_order": "linear_order", "use_render_tracker": 0, "enable_checkpoints": true } My hqueue server is on macOS, if that is relevant. Feeling kinda lost... Edited March 11, 2018 by ubcsdelta Quote Link to comment Share on other sites More sharing options...
ubcsdelta Posted March 11, 2018 Author Share Posted March 11, 2018 (edited) Ok, NVM, installed gnome. Everything works now. HQueue setup was pure fun Edited March 12, 2018 by ubcsdelta Quote Link to comment Share on other sites More sharing options...
