duongduy92 Posted March 13, 2018 Share Posted March 13, 2018 Hello magicians, This is my first post here. I am having an issue with rendering in Houdini using Mantra. I hope you could shed my some light on this. I have been stuck for days. Basically, I have a scene contains 3 spheres, chrome, metal and glass materials and a plane to catch shadow. I'd like to render out the chrome sphere, that has the shadow itself as well as the others two sphere reflections and shadows. I have no success so far in getting the shadows of two remaining sphere reflected on the chrome surface. I would be grateful if you can look into my hip and have some suggestions. Thank you very much. Cheers! 3dComp_v1.hip Quote Link to comment Share on other sites More sharing options...
LaidlawFX Posted March 13, 2018 Share Posted March 13, 2018 Hello Duy. Welcome to the forum. Can you explain the pass you are looking for a bit more? I believe you are pretty close to getting what you want though. I see almost ever combination of what you are describing. If you could reduce the stuff in your scene to just the specifically required assets you are looking for. There are a lot of mantra rops, the textures are missing(you can swap for default Houdini textures if need be), etc. So it's hard to give a quick appraisal, and not send you down a long windy road. Quote Link to comment Share on other sites More sharing options...
duongduy92 Posted March 14, 2018 Author Share Posted March 14, 2018 Hi LaidlawFX, Thank you for a warm welcome. I am surprised that you got exactly my first name. Ha ha. Thank you for replying my post. About the issue, I found out the problem. My light is not strong enough, to cast a clear shadow on the shadow catcher. I also assume the shadow wrong. And all the time, I was looking to create a shadow where it doesn't have to be. Silly me. Thank you again. Quote Link to comment Share on other sites More sharing options...
LaidlawFX Posted March 14, 2018 Share Posted March 14, 2018 Cool. P.S. It says the name at the bottom of the left side identifier. Best of luck on your work. 1 Quote Link to comment Share on other sites More sharing options...
