Scale PolyWire on colonization curves
kiryha
I know a way to scale polywire with UVs and width.
But how to setup proper UVs for each branch? Currently, "Orthographic" Texture Type in uvtexture node gives me a scale in the global coordinate system (I need local space for each brunch). Uniform spline does not work.
Any workaround?
spaceColonization_02_out.hipnc
Edited by kiryha
  • 4 weeks later...
I found a way to manage polywire width depending on the points age. The issue is that it works extremely slow and crashes very soon.
Before polywire node simulation goes very fast and I can build a whole structure for several seconds (around 1000 frames). But with polywire after 80 frames it slows down dramatically and then crashes.
Is there a workaround?
spaceColonization_04_out.hipnc
