How to attach the rbd to wire?
an2050
Hi guys! I had a misunderstanding about relationship of rbd - wire objects. I'm trying to attach rbd to the wire by hard constraint and this gives the result of a one-way rbd effect on the wire. Maybe if we need attach the wire to wall or to electric poles this is will work but  what if there is a situation where we need mutual influence on each other, for example Christmas lights, rope ladder or necklace. What constraints we need to use for this?
I found the example https://vimeo.com/31314814 but I did not understand how it can be used for several objects.
I prepared the simple scene where one sphere should be hang on the wire. How can we do it?
Thank you!
rbd-wire_constraint.hipnc
Edited by an2050
  • 3 years later...
