exporting emission texture to vex variable
shinsso
Hi guys.
I made ash geometry and texture.
I have two textures of using color and glow mask.
Then I use them on Principle shader.
Base texture color and alpha is alright.
but I need another mask for glow.
I tried to use Emission by Texture. This is what I want for glow mask.
How can I export this texture to vex variable?
emission_textures.thumb.jpg.874c3951bf69f9d2bf8deed17ccac62b.jpg5abc8d3c693da_exportingvexvariable.thumb.jpg.3ac5e1bf8f1d3cfc88c4cb40669e2b52.jpg
to get emission channel you can select Combined emission to be exported.
however, for custom shading/texturing and aov workflow you want to use material builder. not just a precompiled shader node which doesn't really offer anything other than very basic features. aovs can be exported using bind_export_VOP (inside material builder).
Thank you David and Atomic.:D
I use attribute from map SOP then I export it by bind_export, naming 'export_emitcolor' inside shader.
So, I could use 'Emission Color(emit_clr)' of mantra's extra channel option.
Otherwise, It was exported as 'other' channel.
