salik Posted March 29, 2018 Share Posted March 29, 2018 Hi all, I have a diagonal plane where I have made a particle flow. While running the sim, I saw that all the particle normals are 'pointing outwards', perpendicular to the plane. I create a sphere, deform it then uses a 'copytopints' node, connecting the sphere and the particles, I saw that the sphere generated on those points are not oriented/ aligned to the surface. Any ideas? Quote Link to comment Share on other sites More sharing options...
Jesper Rahlff Posted March 29, 2018 Share Posted March 29, 2018 can you share you file? Quote Link to comment Share on other sites More sharing options...
dgani Posted March 29, 2018 Share Posted March 29, 2018 In this case, your particles most likely have a velocity attribute. When velocity is present, copy to points prioritizes that value over the normal. You can try promoting your normal value to the orient attribute in a wrangle. Something like @orient = dihedral({0,1,0}, @N) Quote Link to comment Share on other sites More sharing options...
salik Posted March 29, 2018 Author Share Posted March 29, 2018 (edited) Hi all, In the above image, you can see that the sphere is shown as vertically up against a slope surface. Then I try to conform the rotation by changing the sphere orientation to use Z-axis, and so I got the following: Feel free to correct me if I am wrong, but I had thought this will be better when it is cooking the node - vdbsmooth. In any case, still, the sphere is still not being oriented/ conformed to the surface (you can see in the above image, the sphere on the left foreground) This is my file - particles_orientation.hip Edited March 29, 2018 by salik Quote Link to comment Share on other sites More sharing options...
woodenduck Posted March 29, 2018 Share Posted March 29, 2018 if you add some point normals to your grid before the scatter and ray, you will see spheres correctly oriented. Cheers, WD Quote Link to comment Share on other sites More sharing options...
salik Posted March 29, 2018 Author Share Posted March 29, 2018 (edited) 40 minutes ago, woodenduck said: if you add some point normals to your grid before the scatter and ray, you will see spheres correctly oriented. Cheers, WD That seems to have work! Now I have a question - when will I need to add in the use of Normal node? I asked because, initially via the viewport, I was given the impression that all the points generated have normals as defined by the blue lines... Edited March 29, 2018 by salik Quote Link to comment Share on other sites More sharing options...
woodenduck Posted March 29, 2018 Share Posted March 29, 2018 In order to get the normals correctly oriented you need to calculate them before the scatter. This is because the orientation of the polygons associated with a given point determine the normals direction. Quote Link to comment Share on other sites More sharing options...
