Freezing particle transformation but allowing rotation
timur04
Just create a companion goal location for each particle at the start and then when the particles are close enough to the goal location, assign the goal location as the actual location.
To initialize, use a scatter with the scatter count matching your point count. Route that into an attribute wrangle's second input.
v@goal_location = v@opinput1_P;
Pop Wrangle
float distance = length(@P - @goal_location);
if (distance < 0.1) {@P = @goal_location;}
Other forces should still rotate the particle.
