JH12 Posted April 2, 2018 Share Posted April 2, 2018 (edited) Hi, I'm fairly new still to Houdini and was wondering if someone might be able to give me a nudge in the right direction as to how to approach an effect. I want to try to liquify a painting as it hits an object, such as a groundplane, splashing apart into its various colors. At the moment I've been trying the FLIP path, creating a thin box and turning into a FLIP object, removing default water shader and then using a Attributes from Map node at the end of the flip sim to apply colors from a map of the painting to the points. This seems to work ok, the painting maintains a recognisable image as it splashes apart. But to get the painting to appear at a high enough resolution I have to push the point count quite high. I would prefer to be able to use an actual hi res texture map and keep the splash geometry reasonable. Can this be done? Or can you think of an altogether more sensible approach? The other thing this method does not currently achieve is any kind of separation or blending of colors, it simply pulls apart and warps the existing map. I acknowledge this would probably be a separate process applied to the painting texture, but would be interested to know if there's any cops nodes which might help with this warping/bleeding of colors in a 2D image. Sorry bit of a rambling question, but curious to hear any thoughts on any aspect of it, Much appreciated Edited April 2, 2018 by Fireandsmoke Quote Link to comment Share on other sites More sharing options...
JH12 Posted April 2, 2018 Author Share Posted April 2, 2018 (edited) I found this topic https://www.sidefx.com/forum/topic/28148/ from 2013 in which Peter Quint states that there is no simple way to approach this, do we know if this has changed in the last 5 years? The reference video provides a great example of the kind of effect I'm trying to achieve.. Edited April 2, 2018 by Fireandsmoke Quote Link to comment Share on other sites More sharing options...
Atom Posted April 2, 2018 Share Posted April 2, 2018 That is just FLIP with UV mapping. Check out the Daily HIPs of eetu. https://dailyhip.wordpress.com/2017/01/25/fluid-image/ Quote Link to comment Share on other sites More sharing options...
JH12 Posted April 4, 2018 Author Share Posted April 4, 2018 Very helpful, thankyou Atom! Quote Link to comment Share on other sites More sharing options...
