ZengChen Posted April 3, 2018 Share Posted April 3, 2018 Notice that i am not well at English, thanks to you guys to look my topic... I made a digital assets that need to show the inside geo but not the output one. I know that appoint the target geo use Guide Geometry at the node tab of type properties will work, but it only works if the hda is selected, like bend sop (or others) do so I have to add another output to hda, and connected with a null node and template it to always show the target geo. But I really do not want to achieve the aim use this method. Does anybody knows other way to always show geo guide whether the hda is or not selected? Thank you. Quote Link to comment Share on other sites More sharing options...
ranxerox Posted April 3, 2018 Share Posted April 3, 2018 there is currently no way to do this. What you have is probably the best solution. -G Quote Link to comment Share on other sites More sharing options...
vicvvsh Posted April 4, 2018 Share Posted April 4, 2018 Hi! You can make checkbox in your HDA call it i.e "Make Guide Visible" and bind with switch node. First plug in a null node - visible off, second your guide geometry - visible on. Now you can turn it on and off whenever you want. 2 Quote Link to comment Share on other sites More sharing options...
