glue constraint issue
nidhalwes
such behavior happens if you are updating constraint geometry on your Constraint Network DOP every frame
by default this happens if your constraint network geometry in SOPs is Time Dependent, so you seeing this behavior means that it probably is
so either make sure your constraint network is not time dependent
OR
that Overwrite with SOP parm on Constraint Network is 1 only on the frame you want constraints to be updated from SOPs but 0 on other frames, so usually 1 only on first frame of the sim
