PlatinumFishy Posted April 11, 2018 Share Posted April 11, 2018 To be more specific I am trying to make parameter1 equal parameter2 when parameter2 is larger than Parameter1 if(param2 > param1) param1 = param2; ^^this but in the parameter menu Quote Link to comment Share on other sites More sharing options...
davpe Posted April 11, 2018 Share Posted April 11, 2018 (edited) you can simply clamp param2 by param1, can't you? @param1 = 0.2; //0.2 being value you want to clamp to but it can be anything @param2 = clamp(@param2, 0, @param1); Edited April 11, 2018 by davpe Quote Link to comment Share on other sites More sharing options...
PlatinumFishy Posted April 11, 2018 Author Share Posted April 11, 2018 (edited) Sorry if I wasn't clear. I know how to do it in vex, hscript, etc. but I am trying to do this on a control null node. So within the actual parameter interface. Edited April 11, 2018 by PlatinumFishy Quote Link to comment Share on other sites More sharing options...
StepbyStepVFX Posted April 12, 2018 Share Posted April 12, 2018 6 hours ago, PlatinumFishy said: Sorry if I wasn't clear. I know how to do it in vex, hscript, etc. but I am trying to do this on a control null node. So within the actual parameter interface. In the interface, I am not sure a parameter can refer to himself in the expression. Therefore, I think your need to create a third parameter that will take min of both values, and use this value instead of parameter2 OR, create a new parameter where you set a value of « parameter 2 » (altough this is a dummy paramater), and in parameter 2 you take min of parameter1 and the value of new parameter... To create another parameter on a node you need to click on the cog, and edit parameter interface. There you can create a parameter with the type you want. Quote Link to comment Share on other sites More sharing options...
vicvvsh Posted April 12, 2018 Share Posted April 12, 2018 8 hours ago, PlatinumFishy said: To be more specific I am trying to make parameter1 equal parameter2 when parameter2 is larger than Parameter1 if(param2 > param1) param1 = param2; ^^this but in the parameter menu Hello Andrew ! In this condition param1 never will bee smaller then param2. If this is OK for you then see hip. params.hipnc Quote Link to comment Share on other sites More sharing options...
konstantin magnus Posted April 12, 2018 Share Posted April 12, 2018 Isnt there a python way to limit sliders? So "red radius" can never be set higher than "blue radius". Without having a third parameter that does the clamping? Quote Link to comment Share on other sites More sharing options...
vicvvsh Posted April 12, 2018 Share Posted April 12, 2018 Hi Konstantin! Maybe there is solution with python for it but I know python not good unfortunately. In my hip red radius may be bigger but not smaller. Whereas blue radius may be smaller but not bigger. I don't know what exactly the goal Andrew wants to achieve is. Quote Link to comment Share on other sites More sharing options...
