felix Posted October 11, 2002 Share Posted October 11, 2002 Did anyone sucessfully setup Mantra to utilize two CPUs in the same machine . I typed render command : mantra -H localhost,localhost , but it seemed like only one CPU is working , when I press the render button everytime. Quote Link to comment Share on other sites More sharing options...
Jason Posted October 11, 2002 Share Posted October 11, 2002 It works swimmingly on our Linux and NT workstations exactly like that. Are you sure it's not working? There must be something odd going wrong. Quote Link to comment Share on other sites More sharing options...
TheUsualAlex Posted October 11, 2002 Share Posted October 11, 2002 Hey Felix, what version of Houdini are you running? Is you lic server same as your workstation? I have ran into that problem a while back, but I can't recall how it was fixed... Quote Link to comment Share on other sites More sharing options...
Jason Posted October 11, 2002 Share Posted October 11, 2002 Ah - too true, Alex. Well remembered! If you do an "hserver -l", you'll see the license server version. Make sure it's the same version as Houdini. If not, you may have to uninstalled Sesinetd and re-install it with the matching version. I remember it was: sesinetd -qu; sesinetd -is I don't know if this has changed recently or not... I suspect it has.. J Quote Link to comment Share on other sites More sharing options...
chang Posted October 12, 2002 Share Posted October 12, 2002 What a great tip ! Triple thanks. And it works on mantra only, right? Not for Omantra. Quote Link to comment Share on other sites More sharing options...
tuangD Posted October 12, 2002 Share Posted October 12, 2002 I think on Omantra you can set number of CPUs.... Am I right?? Quote Link to comment Share on other sites More sharing options...
felix Posted October 14, 2002 Author Share Posted October 14, 2002 Hey Felix, what version of Houdini are you running? Is you lic server same as your workstation? I have ran into that problem a while back, but I can't recall how it was fixed... Thanks for all your suggestions / tips. I am using Houdini 5.5.36 that installed from Apprentice CD . I checked license server name and version . They both match to my machine name and software version . Is Mantra in Apprentice version do not support multi-precessors ? Finally, I may leave it alone as it render faster if I type "Mantra" only in render command . Quote Link to comment Share on other sites More sharing options...
