Beginner VEX variable questions
Christoph_H
$NPT is the same as @numpt. @npt doesn't work in vex, you'd want to use @numpt or I prefer to use npoints(0) or npoints(1)... and so on, where the number inside () indicates which input you want to pull the info from. Also, you can use npoints() in SOPs as well to stay away from the $NPT syntax which I guess is sort of going away.
@elemnum contains current element number
so when iterating over Points it's the same as @ptnum, over Prims the same as @primnum, over Vertices the same as @vtxnum, over Numbers it's the current number
same equivalency for @numelem
