hm ... i'm trying to get more into CHOP .. since I need to better handle animation as well in houdini...
but I'm already having my first hard step in it.
Fetch CHOP op .. can I fetch a /obj/model/xform1/rz curve with it?... apparerntly nope.
it seems like i can only fetch /obj/model/rz .. which is quite odd to me.
any advice is really appreciated.
cheers.
FetchCHOP is working fine here with 8.0.394.
Is your animation done by expression or key-frame?
If  it's only expression, you may need to use "Use Start/End" as Channel Range in Channel tab.
Cheers,
Sho
22971[/snapback]
ahh right .. thanks a lot .. yeah it was driven by expression .. and that fixed.
cheers.
I just post in this thread since is.. sort of related..
i'm stuck again.. this time doing the opposite.
simple scene
grid.. box.. copy sop which copy the box on the grid's points
stamping a variable "posiy" which have the following value
chf("/ch/ch1/math2", ($F+$PT))
nothing happens. no errors tought.
ok.. even simpler example i'm stuck with:
box... xform sop ... ty with the following expression:
chf("/ch/ch1/math2", $F)
nothing happens, no errors tought.
WHERE am I wrong?... cant i "fetch" (or just scope in this case) a channel, whatever it is (this is generated from a wave and a noise, simple), from any OP using "chf" function?
any help is really appreciated.
cheers :)
