iamjaideep80 Posted December 9, 2005 Share Posted December 9, 2005 Hi Everybody... Facing a problem. For doing some Feather tests, I want to adjust the normals of a geometry, using its UV coordinates. I can comb the normals, but I think UV is a better choice. The idea is to create a Vex Geometry Op, which takes UV info for a point and its neighbours, Finds the neighbour point having Greater U or V value and make the Normal to Point to that Direction. That way, I can get all the normals pointing in one Direction or Flow (U or V). But the problem is, UV info is only available in Shading Context, and not in Geometry Context. I know that only Vertices can have UV Info, but is there any way I can get it in VEX Geometry Op???? Plz Help. Thanking in advance. ------------iamjaideep80 Quote Link to comment Share on other sites More sharing options...
AndrewVK Posted December 9, 2005 Share Posted December 9, 2005 Add "Parameter VOP" name: uv type: vector hidden: checked Append "Vector To Float VOP" fval1 - U fval2 - V Quote Link to comment Share on other sites More sharing options...
Mario Marengo Posted December 9, 2005 Share Posted December 9, 2005 What Andrew said. But if you're looking for *parametric* UVs (as opposed to *texture* uv's, which is what adding a "uv" parameter will extract), then you're out of luck. In a surface shader (Mantra, PRMan,...), (s,t) get assigned the parametric uv's when not bound to the surface -- no such thing in the SOP context. Just wanted to clarify that Andrew's solution assumes your geometry already has *texture* uv's defined (via one of the UVxxxx projection SOPs, for example). Just for fun, try and take the output of Andrew's parameter vop, multiply it by the constant vector {1,1,0}, pipe the result straight to the "P" output, and voila! -- instant "UV viewport" Cheers! Quote Link to comment Share on other sites More sharing options...
DaJuice Posted December 9, 2005 Share Posted December 9, 2005 Vertex UVs don't work in the vex geometry context btw. You can use point UVs, or maybe try to modify your normals in SOPs? UVs are accessible in the Point SOP ($MAPU, $MAPV, $MAPW). Quote Link to comment Share on other sites More sharing options...
iamjaideep80 Posted December 10, 2005 Author Share Posted December 10, 2005 Hi Everybody, Thank U Everybody.. Parameter Vop for uv attribute works, but only if there are uv attributes on points, instead of vertices. And Point Sop's MAPU/V/W did the same thing. It transfered Vertex Info To Points. And My Vex Op is working fine now. I can align normals according to U or V direction. But still having some bugs. For Example, when I have multiple UV patches for a single geometry. In that case, the points on the patch border doesn't align properly. Trying to solve that problem. Anyway, Thank u very much Andrew, Mario And DaJuice for ur instant reply. ---------iamjaideep80 Quote Link to comment Share on other sites More sharing options...
sibarrick Posted December 10, 2005 Share Posted December 10, 2005 Don't forget import VOP too, if you want to get UV's or any attribute from a specific point use the import VOP. And if you need to do quick neighbourhood searching and gathering of attributes use point cloud VOPs (although when I last tried this the VOPs were broken you had to do it with VEX code by hand - hopefully its fixed by now) Quote Link to comment Share on other sites More sharing options...
