Importing code into the VOPs
Lukich
Or you can convert existing code to VOP format files if you process it with "vcc -p <file.vfl>". You are left to place the code in the relevant location and refer to it in the "VOPall" file under $HFS/vop and then it will appear under the VOP list. This works much in the manner as installing vex operators (SHOPs/SOPs/etc) and it's documented in the manuals.
Cheers,
Jason
