davedjohnson Posted January 10, 2006 Share Posted January 10, 2006 I'm interested in using the hdr skyprobes that Paul Debevec has on his website to do some testing. I can read the images without any trouble with mplay, but the arrangement of them seems like it would be complicated to use as a reflection map or projection map with global illumination. It says they are angle maps, which to my eye looks like they are just the regular image that you would get when photographing a gazing ball. My next step would be to go and shoot my own images, but the projection still seems to stump my mind. Does anyone have any suggestions on how to project the mirror ball into a reflection map? Dave Quote Link to comment Share on other sites More sharing options...
Jason Posted January 11, 2006 Share Posted January 11, 2006 If you download HDRShop from Debevec's site, I believe it supports some panoramic transformations from Angle/MirrorBall to LatLong. Quote Link to comment Share on other sites More sharing options...
davedjohnson Posted January 11, 2006 Author Share Posted January 11, 2006 Yeah, well not to start any OS wars, that requires using Windows. Using HDRShop is not enough reason for me to add a Windows machine to our pipeline/shop/existence. I was hoping that someone might have a clever algorithm or Linux/Mac based solution. Maybe I'll find a friend who has a Windows machine to try it out on and figure out how to do the transformations myself. If I do, of course, I'll share here. Dave Quote Link to comment Share on other sites More sharing options...
crunch Posted January 11, 2006 Share Posted January 11, 2006 davedjohnson said: Yeah, well not to start any OS wars, that requires using Windows. Using HDRShop is not enough reason for me to add a Windows machine to our pipeline/shop/existence. I was hoping that someone might have a clever algorithm or Linux/Mac based solution. Maybe I'll find a friend who has a Windows machine to try it out on and figure out how to do the transformations myself. If I do, of course, I'll share here.Dave 23567[/snapback] isixpack has a mode which reads the cross style images to create an environment map. Run "isixpack" to see the help. Quote Link to comment Share on other sites More sharing options...
Mario Marengo Posted January 12, 2006 Share Posted January 12, 2006 Hey Dave, If you want to map a probe directly to latlong, then you can use the projection that they give you in Debevec's site. They provide you with spherical<->probe, so all you need is latlong<->spherical (with the spherical projection as the common space). Here's a quick'n'dirty implementation as a VOP COP: Probe2Latlong.zipFetching info... I wanted to preserve the VOP network so you could see/modify it, that's why it's a cpio file. To load it into houdini, open up the textport and type: / -> opcf /vex /vex -> opread Probe2Latlong.cpio Then go into COPs and add a "Probe2LatLong" COP. Override the image size to something like 1000x500 (or anything that's twice as wide as it is high) and point it to one of debevec's probe files (not the envcube crosses, but the actual probe images). You should see a panoramic (latlong) version of it in the viewport. <edit> Also remember to change the bit depth to 32-bit float, or half </edit> Please note that this is a *very* simple implementation of the projection math. It doesn't deal with any kind of filtering at all (although if you're using these for diffuse illumination then it probably doesn't matter since you'll likely end up blurring the heck out of it anyway ). If you need better quality, you should do stochastic sampling over the source quad -- meaning that you should project not just XY, but rather [XY,XY+dX,XY+dY,XY+dX+dY] and pass all four to the colormap() function (along with the number of samples). I would have done it except it's late and I don't feel like doing that kind of thing in VOPs (the projection should be its own function, etc, etc)... Anywhoo... hope that helps get you started at least. Cheers! Quote Link to comment Share on other sites More sharing options...
Marc Posted January 17, 2006 Share Posted January 17, 2006 We actually have the preconverted, rat-ified versions here on odforce : rats Just for a quick fix if you need it . M Quote Link to comment Share on other sites More sharing options...
Mario Marengo Posted January 17, 2006 Share Posted January 17, 2006 Marc said: We actually have the preconverted, rat-ified versions here on odforce :rats 23808[/snapback] Yup, those are definitely useful to have, but I think he's planning to shoot his own probes, in which case you need some way to go from the probe's projection to one of the standard environment projections (latlong or cube). The little VOP-COP I posted does the probe-to-latlong mapping (w/o filtering). Quote Link to comment Share on other sites More sharing options...
Marc Posted January 17, 2006 Share Posted January 17, 2006 davedjohnson said: I'm interested in using the hdr skyprobes that Paul Debevec has on his website to do some testing.23527[/snapback] I was responding to this part ... they're good for testing. Quote Link to comment Share on other sites More sharing options...
