Quadro 980 And Dual Monitor
Hi there,
I'm using Dual monitor since a week at work were we have Quadro 980 Graphics board and on the right monitor (secondary) all is extremely slower than the main screen .. the network viewer move slowly... anyone have same problem?
Drivers  Forceware 71.84
Windows XP Sp2
cheers.
23550[/snapback]
hi,
I'm using the same configuration. no differenz between left and right
driverversion: 6.14.0010.8176 (81.67_forceware)
cheers
Hi!
There are two different ways to setup dual monitors in Windows. One is the Microsoft way (often refered to as DualView, I think) and the other is nView from nVidia. DualView can be configured in the Display Properties dialog of Windows. nView will be setup in the advanced settings of the graphics card.
If you use DualView, the card will setup two framebuffers. Only one of both is hardware accelerated. If you use nView, the card configures one framebuffer, that spans both monitors. So you have hardware acceleration on both screens.
hth
Frank
