Add Vertex to Prim
CinnamonMetal
I guess you should not squeeze functions into one another (eg point() into lerp()). This works in a primwrangle:
float slide = chf('slide');
int prim_pts[] = primpoints(0, @primnum);
vector pt_pos_0 = point(0, "P", prim_pts[0]);
vector pt_pos_1 = point(0, "P", prim_pts[-1]);
vector pos = lerp(pt_pos_0, pt_pos_1, slide);
int pt = addpoint(0, pos);
int midpoint = addvertex(0, @primnum, pt);
  • Thanks 1
I was already storing the primVertices in an array followed by getting the index of two of the primitives vertices and storing them in a variable.
vector pt_pos_0 = point(0,"P",vp1);
vector pt_pos_1 = point(0,"P",vp2);
Since I'm using a variable from what I know I can't use -1; then followed linear interpolation etc.  The problem is the vertex order is not consistent as in it changes causes the object to have it's normals all inside and out in the viewport ?
My previous post didn't make much sense :mellow:
When adding a vertex to a primitive, this is the result; rather then the vertex added to the primitive while keeping the normals in tact, unless this is expected in shaded mode ?
Is it possible to re-position the vertex before it's essentially baked onto the primitive ? The slide parameter re-positions the vertex which alters the primitive.
Edited by CinnamonMetal
