A Problem
NULL2 is parented under NULL1, then NULL1 is moved somewhere in the space, rotated and scaled.
Another transform - NULL3 - is moved somewhere in the space.
How can i match the position of NULL2 to NULL3 ?
Basicly my question is how to read/edit the world matrix of NULL2 ?
The solution must be only through hscript/expressions.
Thanks.
actually first i looked at any solution allowing me to directly edit the transformation matrices.
then i tried the *origin expressions, but they didn't worked. the reason for that was that i had hierarchy with several objects and all the time i tried to use the root one in the vtorigin expression - vtorigin("rootObject","whateverObject"), instead of vtorigin("theOneAbove","object").
after edward replied me, i figured out my mistake somehow.
The implicit way provided by the *origin expressions is good enough.
thanks.
