Disablewhen And Inputs
Hi there,
I have an HDA which has a field of type string/operator-path. I'd like to disable this field if there is anything wired into the operator. Does anyone know if this is possible?
Basically I would like the user to either connect a wire to this node OR specify a node in the string field.
Any ideas if disablewhen can accept expressions at all?
Thanks,
Jason
welll first of all...this should be in General Houdini, not general Chat :)
the 'disable when' thingajig doesn't accept expressions, just parameter|value pairs
so what you could do is set up a dummy parm called has_input at the top level
then inside rig up an integer parameter with a opninputs("") > 0 expression that sends a 0 when there is no input and a 1 when there is...then test that param in the 'disable when' of the parameter you want to control...kinda hacky but I think it would work....
HTH
