kubabuk Posted March 9, 2006 Share Posted March 9, 2006 Is there a simpler way to extrude face along the curve? I fond some kind of workaround but it only works for cirular/eliptical shapes... thank's in advance for any reply kuba Quote Link to comment Share on other sites More sharing options...
LEO-oo- Posted March 9, 2006 Share Posted March 9, 2006 Try the sweep- and skin-function - maybe it works better for you. Quote Link to comment Share on other sites More sharing options...
kubabuk Posted March 9, 2006 Author Share Posted March 9, 2006 Thanks that is exactly what I was looking for The tricky part is to resample a curve to get smooth transition. BTW how can I attach an image with the "click to enlarge" option? Quote Link to comment Share on other sites More sharing options...
MG Posted March 10, 2006 Share Posted March 10, 2006 Try the sweep- and skin-function - maybe it works better for you. 25493[/snapback] You don't have to skin it manually, and with an extra/seperate Skin SOP, you can also skin it inside the Sweep SOP (see the "Output" tab). Quote Link to comment Share on other sites More sharing options...
Mcronin Posted March 10, 2006 Share Posted March 10, 2006 BTW how can I attach an image with the "click to enlarge" option? 25526[/snapback] When you post or reply, there's a little field in the page below the emoticons for attaching files. Attach your file there and it will be uploaded to the forum and presented with "click to enlarge". Quote Link to comment Share on other sites More sharing options...
michael Posted March 10, 2006 Share Posted March 10, 2006 or ask an admin to do it for you Quote Link to comment Share on other sites More sharing options...
kubabuk Posted March 13, 2006 Author Share Posted March 13, 2006 or ask an admin to do it for you 25539[/snapback] aaaaa! here it is! I used IMG code tag to attach the file, but I can see that there is more convieniant way of doing that. thanks for suggestions Quote Link to comment Share on other sites More sharing options...
tomboessel Posted August 2, 2006 Share Posted August 2, 2006 Is there a way to put a scale on a single point on the curve, so that it could have a tapered effect? Quote Link to comment Share on other sites More sharing options...
RickWork Posted August 2, 2006 Share Posted August 2, 2006 Is there a way to put a scale on a single point on the curve, so that it could have a tapered effect? Hi, In the scale channel on the sweepSop type an expression like ($PT+1) *.06 I think in the sweepSop's helpcard there's an example that demonstrates this. Cheers, /Rick Quote Link to comment Share on other sites More sharing options...
tomboessel Posted August 3, 2006 Share Posted August 3, 2006 That worked wonderfully, thank you Quote Link to comment Share on other sites More sharing options...
