Extrude Along Curve
kubabuk
  LEO-oo- said:
Try the sweep- and skin-function - maybe it works better for you.
25493[/snapback]
You don't have to skin it manually, and with an extra/seperate Skin SOP, you can also skin it inside the Sweep SOP (see the "Output" tab).
  kubabuk said:
BTW how can I attach an image with the "click to enlarge" option?
25526[/snapback]
When you post or reply, there's a little field in the page below the emoticons for attaching files. Attach your file there and it will be uploaded to the forum and presented with "click to enlarge".
  • 4 months later...
  tomboessel said:
Is there a way to put a scale on a single point on the curve, so that it could have a tapered effect?
Hi,
In the scale channel on the sweepSop type an expression like ($PT+1) *.06
I think in the sweepSop's helpcard there's an example that demonstrates this.
Cheers,
/Rick
