How To Change Uv's Of Instanced Objects
Hello,
I"m trying to point instance some boxes and I want to project (orthographically) a texture over the boxes so that the texture will cover all of the boxes (as oppposed to projecting it on one box and duplicating this box).
I"m trying to build a VEX shader for it, but the problem is I can't find out the location of my instanced box. I only know P in world (screen) space or in texture / object space which is per box and not relative to the whole bunch of them.
Must I use a procedural instance script?
Thanks
You could convert instance positions into NDC space and use that to look up a texture.  Here's a quick example..
25942[/snapback]
Thanks,
but I ment for something a bit different.
I want the projection to be orthographic and not 'camera projection'.
So, knowing the position in screen space is not enough...
Here is an example of what I want to do( using 'copy' instend of instancing).
Thanks.
example.zip
