Occlusion And Displacement Problem
hi,
i am trying to render an occlusion pass with displacements using this occlusion shader:
surface occsurf3(float samples = 64, maxdist = 1e30, coneangle = PI/2)
      normal Ns = faceforward(normalize(N),I);
      float occ = occlusion(P, Ns, samples, "maxdist", maxdist, "coneangle", coneangle);
      Ci = (1 - occ) * Cs * Os;
      Oi = Os;
it seems to work ok without displacement but when i render with displacement it doesnt look good, where am i going wrong?
thanks in advance
amir
26148[/snapback]
Some initial thoughts:
Does it look any better if you crank up the number of samples? If it's a polygonal mesh, are you using N and Ng in your call to computenormal(), or only P?
Can you post the displacement shader you're using?
Cheers!
here is what the vop net looks like. I have tried rendering with more samples and is still the same.
26162[/snapback]
Hmm ... not sure what to immediately suggest. Does a diffuse/specular render look "ok"? Can you post your scene for us to play with?
