rootboot00 Posted May 15, 2018 Share Posted May 15, 2018 (edited) Here's a problem with Redshift render :S I made particles and wanted to render it. but When I make particles to mesh by using Redshift OBJ Parm(Particles tab -> Render Object as Particles), I can see motion blur on rendering but It cannot be used as geometry light. I set up the geometry light with rslight(change Light type to Are and link Mesh object). So, I copyied spheres to particle points instead using Redshift OBJ Parm, and that moment, I could use it as Geometry light. How could I use both ?? so, problem is 'I want to use particle spheres and wanna us it as geometry light too' Sorry for my poor English and Thanks for read Edited May 15, 2018 by rootboot00 Quote Link to comment Share on other sites More sharing options...
Sepu Posted May 15, 2018 Share Posted May 15, 2018 (edited) you cant use the particle tech for emitting light (mesh light) unless you want to use the rs_incandescence. You would want to use instancing in that case. Edited May 15, 2018 by Sepu Quote Link to comment Share on other sites More sharing options...
