Rival Consoles Posted June 13, 2018 Share Posted June 13, 2018 Hello, I just installed Linux Kubuntu18.04 and so far, everything is going well in Houdini. However, all my 3D files are on a secondary internal hard drive and i can't see it inside Houdini. In Linux, i can see it normally in the "Devices" section. How can i make the second HD visible inside Houdini? Thanks. Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted June 21, 2018 Share Posted June 21, 2018 It's likely a permissions issue. Does the user running Houdini also own the drive/directories? Is it a Linux native file system? Quote Link to comment Share on other sites More sharing options...
Rival Consoles Posted June 21, 2018 Author Share Posted June 21, 2018 Hey @lukeiamyourfather , thanks for your answer. I figured out what happened and it was easier than i thought. So in Linux, the secondary/external hard drive is mounted under the "Devices" and "Media" folder structures. The "Media" one is the catch. Inside Houdini, i just had to point the project file structure to "Root(/)/Home/Media/UserName" and there it is. The HD shows as it should. Cheers Quote Link to comment Share on other sites More sharing options...
