sschoellhammer Posted June 22, 2018 Share Posted June 22, 2018 Hello, I want to cut a mesh with multiple curves so I tried creating a for-each loop with multiple inputs as describes in the documentation here: http://www.sidefx.com/docs/houdini/model/looping.htmlpolysplit_by_mulitple_curves_2.hip Sadly I can't get it to work, could somebody please point out my mistake? (I can do it by blasting away the other non needed curves using a meta node but I thought this should be possible without..) Thanks a lot!! seb Quote Link to comment Share on other sites More sharing options...
kiryha Posted June 22, 2018 Share Posted June 22, 2018 (edited) You need to cut a plane with several curves. So, you need to do a split for each curve, hence loop through curves, but not through the plane. polysplit_by_mulitple_curves_3.hipnc Edited June 22, 2018 by kiryha Quote Link to comment Share on other sites More sharing options...
sschoellhammer Posted June 22, 2018 Author Share Posted June 22, 2018 Sigh... my houdini learning journey continues thanks Kiryha !!! Quote Link to comment Share on other sites More sharing options...
probiner Posted June 25, 2018 Share Posted June 25, 2018 (edited) Just a heads-up. That setup will create copies for each cut, not a single grid with multiple cuts. For that you need a loop with two begin blocks, one set to fetch feedback for the grid and another set to fetch piece for the curves. There's two ways that you can set it up, as in the image and attached scene file. Cheers PRB_PolySplitLoop.hiplc Edited June 25, 2018 by probiner 2 Quote Link to comment Share on other sites More sharing options...
