CinnamonMetal Posted June 23, 2018 Share Posted June 23, 2018 How do you change the default Voronoi pattern, if it's possible when the Voronoi pattern is based on points. Either that or merge points so the Voronoi patterns are joined ? Quote Link to comment Share on other sites More sharing options...
gfern93 Posted June 23, 2018 Share Posted June 23, 2018 If you open up the Example Files in the help menu, there's a great example file called "FractureExamples". Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted June 24, 2018 Author Share Posted June 24, 2018 Know the name of the example file I should look for that would aid in helping ? Quote Link to comment Share on other sites More sharing options...
