Proper method of working with Dual Rest positions when adjusting Time Scale to create slow moving smoke?
Wenye
I'm accustomed to adding additional detail to smoke using the Pyro Shader by creating dual rest attributes and using those to generate Noise with the shader. It seems though when I adjust the Scale Time on the DOP Network node, something becomes off. In my attached video, you can see that the Noise of the Pyro Shader is causing a popping every 30 frames. I'm not sure how to resolve this issue and any tips would be much appreciated. Thank you.
smokeTest_001.mov
SOLVED: simply use the pyro solver's time scale instead of the DOP's
Edited by Wenye
SOLVED
