list of vertices
Do you want to iterate over the vertices in the same node, or for some reason store them in an attribute ?
http://www.sidefx.com/docs/houdini/vex/geometry.html
http://www.sidefx.com/docs/houdini/vex/functions/vertex.html
<type> vertex(<geometry>geometry, string attribute_name, int prim_num, int vertex_num)
<type>[] vertex(<geometry>geometry, string attribute_name, int prim_num, int vertex_num)
Specifies the vertex as a primitive number and then an offset into the list of vertices on that primitive.
I want to store them as an attribute, for each primitive of the polygon (triangle) its three vertices;
Could the expression be something like:
int prim_vertices[];
@prim_vertices = primvertices(0, @primnum);
The problem is I don't know how to use them correctly. Please can you tell me how I could write the full expression?
To put the vertices in an array attribute:
i[]@prim_vertices = primvertices(0, @primnum);
You have to declare @prim _vertices as an array. You don't need the first line of your code, that would declare a variable. Unless that's what you want of course
