polterizer Posted July 5, 2018 Share Posted July 5, 2018 (edited) Hello guys, i am trying to get only the vel of smoke using wiith "gas curve force" but i see 2 vels, the smoke + curve.... how i can get only te smoke vel? NOTE: i tried multiply vel with density (@vel*=@density;) but that is not what i want, still have 2 vel as density form.. the idea is just export the vel of smoke only. any ideas? hip at bottom if you want try. thanks in advance. smoke_curve.hip Edited July 5, 2018 by polterizer Quote Link to comment Share on other sites More sharing options...
fencer Posted July 6, 2018 Share Posted July 6, 2018 (edited) Do you want just see in viewport vel without gascurveforce guide or what? Edited July 6, 2018 by fencer Quote Link to comment Share on other sites More sharing options...
polterizer Posted July 6, 2018 Author Share Posted July 6, 2018 not exactally, i want export the vel of the smoke wheres moves into the path curve... not the curve vel... because it will affect in other sims.. example look the screen.. i know one solution is multiply with the density for remove outside smoke vel, just curious to see if is there other better way because still have smoke+curve vel. Quote Link to comment Share on other sites More sharing options...
fencer Posted July 6, 2018 Share Posted July 6, 2018 (edited) Looks like you mix all sims in one dop? Resulting velocity from pyro sim will be limited with bounding. Edited July 6, 2018 by fencer Quote Link to comment Share on other sites More sharing options...
