Coyote_Actual Posted July 6, 2018 Share Posted July 6, 2018 Hey All, I'm trying to figure out why I can't get Redshifts puzzleMatte AOV to work.. I understand the workflow in Redshift for Maya, as its pretty easy to set an objects ID.. where as in Houdini I'm not quite sure where to set the SOP's object ID. I've even tried Material ID right in the RS_Material node and still no dice. What is the proper workflow for something like this? Do I create a wrangle and set the ID in there? or is there some sort of parameter that i need to create in the interface? The issue is I'm not sure what variable (if it is at all) Redshift is looking for on the points? prims? detail? I'm a bit lost, and there doesn't seem to be any tutorials or posts about this! Cheers, -J Quote Link to comment Share on other sites More sharing options...
toadstorm Posted July 6, 2018 Share Posted July 6, 2018 Add RS OBJ properties to your geometry container. From there you can set the Object ID. Quote Link to comment Share on other sites More sharing options...
Coyote_Actual Posted July 6, 2018 Author Share Posted July 6, 2018 Hah of all the places I looked for object properties.. the shelf was not one of them! *facepalm* Thanks! p.s. is there a way to add these properties without using the shelf? Quote Link to comment Share on other sites More sharing options...
