Paint pieces when glue constraint break HELP
Hi. It works well. thank you!!! But can you explain. why my setup doesn't work, why do you use this path /obj/AutoDopNetwork/glue_box_object1:Relationships/glue_box_object1/constraintnetwork/Geometry instead import relationship. like in my setup. thank you.
