need to know the attribute of neighboring points
Hey, you can find the point numbers of neighbouring points using the 'nearpoints' vex function. That will return an array of point numbers from the nearest to the furthest. Then from there, you can reference the nearest point number in a point() expression to retrieve the value of the attribute. However I'm not sure what you mean by "left", since left will change depending on the angle of view. Could you clarify what you mean?
59 minutes ago, Valent said:
Thanks for the reply, Stephen!  It's not the attribute from any closest point that I need, but I'd like to know which of the neighboring points possess certain attribute.
In that case, you can still use the nearpoints expression and then iterate through the array with a foreach loop to check if each of them posses that attribute
Edited by Stephen Moroz
