Getting: Segmentation Fault crash when snapping screen-size
I've just installed Houdini on my new laptop (it runs an AMD RX 580 and a Ryzen 1700) and i'm getting crashes everytime i try and snap the Houdini window to either top for full screen, or left/right for half screen (a Windows 10 feature). It seems to run OK when using it otherwise (though i've not really done any extensive tests) but whenever I drag the window it gets "11064: Fatal error: Segmentation fault", or similar.
I tried changing the GPU Tdr delay value (like in this tutorial - https://support.allegorithmic.com/documentation/display/SPDOC/GPU%2Bdrivers%2Bcrash%2Bwith%2Blong%2Bcomputations and it seemed to work for a few times, but then it went back to crashing again. I've tried Adobe Premiere Pro, Illustrator, Photoshop and Zbrush, none of them have this issue of crashing. Perhaps Houdini's not registering the GPU??... I have no idea.
Any help would be really appreciated.
FIX:  Realtek Drivers mess with Houdini. Deinstall the using Method 2 - https://appuals.com/how-to-disable-windows-10-from-automatically-installing-realtek-drivers/ [appuals.com]
Edited by Snappy_Darko
