Copy Node
I have a growing geometry, (via finding "neighbours" creating goup and than blast the geometry)
and I want to copy/stamp objects to points of this growing mesh...
But as it is growing the point numbers changing so the stamped scale/ rotation etc... is changing also...
Any Idea for some solution or workaround?
Thanks
BK.
Hard to help without a scene file. But if i had to guess, maybe the base geometry your points are growing on has a noise or animated seed on it? You can visualize the point numbers on the viewport and check node by node where the point numbers are changing. Hope this helps!
