Particles avoiding objects
logix1390
Hello,
I am trying to make my particles avoid an object as they move along the Z direction. My object in this case is a sphere plugged into the second input.
I have tried the pop axis force which technically works...however it becomes very hard to control when I add more forces to the particles like the pop wind.
I tried the pop attract with negative values but the particles end up accelerating which is not what i want....
 also tried the "pop steer obstacle". which is also very hard to control..
I feel like I am going down the wrong path here.
Any tips will be greatly appreciated.
I will attach my scene file for any one that wants to take a look.
Thank you.
avoid_object_pops.hip
  On 7/14/2018 at 10:33 PM, logix1390 said:
Hello,
Thank you.
avoid_object_pops.hipFetching info...
Expand
Have a look at this, if you haven't,it might solve your purpose.
Cheers !!
Thank you karanjaura, this is exactly the effect I needed. Works perfectly.
But I am just wondering...is there an easier way to achieve something like this? I was assuming Houdini would have some built in tools to make particles avoid objects...Surely a beginner would not come up with a solution like in that video.
Really appreciate the help!
Expand
Hi Mike,
Glad it worked for you,I'm sure there must be other ways to accomplish the same effect and being a beginner myself too,I am also learning the tricks and trade of Houdini every single day :) and diving in Vops context feels scary at times :unsure:
Cheers !!
