logix1390 Posted July 17, 2018 Share Posted July 17, 2018 Hello, I have two emitters that are emitting packed objects every frame. I want to apply a unique pop wind for each emitter to give each emitter it's own velocity direction. I have it all setup, I just need a way to get the pop forces to know which rbd packed object to apply it to. It seems as if the group option in the pop wind does not pick up on the rbdpacked object, perhaps for obvious reasons. Is there a way i can get my forces in pops to talk to the rbdpackedobject? I have a multisolver setup . I will attach my file for anyone that wants to take a look. Thank you popforces_talking_to_rbdpacked.hip Quote Link to comment Share on other sites More sharing options...
logix1390 Posted July 18, 2018 Author Share Posted July 18, 2018 anyone? Quote Link to comment Share on other sites More sharing options...
Noobini Posted July 18, 2018 Share Posted July 18, 2018 (edited) just fumbling around...don't take this as an expert solution.... popforces_talking_to_rbdpacked_vu.hipnc (if you don't want to bother with transferring group in the assemble, you can wipe that out, move the group SOP to below the assemble, change to Points...works the same) Edited July 18, 2018 by Noobini Quote Link to comment Share on other sites More sharing options...
logix1390 Posted July 18, 2018 Author Share Posted July 18, 2018 Works great Noobini. Thank you for the help! Quote Link to comment Share on other sites More sharing options...
