How to constrain packed prims using hard constraints in space?
I have a grid of packed prims where I create hard constraints between them. This works well. But now I want to create hard constrains on the outer pieces to be fixed in space using hard constraints. I did this too, where one point of these hard constraints refer to the piece, while other's name attribute is set to "". In DOPs, I see that the constraint links for these pieces start at the correct place but the other end is at the origin.
How can I fix this?
Thanks a lot :)
