Point Levelling Question
Hey guys,
Sorry for the bad title wasn't sure what to name this exactly.
So my issue is as follows, I have a curve which I'm raying onto a mesh - all good.
I'm then trying to make sure each point is not higher in y than the previous point. And if so use the previous points position in Y (roughly).
Ive tried several setups using the logic of select points higher in y than surrounding points - but then I think I maybe need to find its neighbours and their average point position in Y and apply that to the points which are higher in Y? [As I was typing this I came up with that thought so going to see if that works]
Any ideas would be great,
Thanks :D
