houdini python and mply
mohamaedkamal
  • 2 years later...
Hi Bunker,
thanks for the help.
Nope, I am afraid that didn't seem to work.
my evaluated end of the string looked like this when I replace $F4.
/geometry/moreframes/box.*.bgeo
Googling this I can't seem to find any info on this problem.
when picking files manually I noticed it had the frame range in () at the end of the string.
like (1-240)
but i tried this also adding to the end of the string. but it didnt work. unless it needs to be in a tuple or something.
cheers
Daniel
Hi Again Bunker,
thanks so much for your help. im still clutching at straws here.
the function I'm building is basically being run off a right-click menu in a QT widget window. Don't know if that makes a difference.
this is the last part of my function for testing purposes.
filePath = filePath.replace("$F4", "*")
command = 'gplay ' + filePath
subprocess.Popen(command,shell=True)
this is the whats my command variable prints like
gplay C:\Users\Daniel\Documents\NodeShare\Geometry\moreframes\box.*.bgeo
and it's still throwing an error. and yeah I am importing subprocess its at the top of my function.
just get this error.
hou 18 - python 2.7
cheers
Daniel
thanks for the heads up malexander.
after a bit of tinkering, I did finally get it to work....
few things to look out for.
in your list of file paths
firstly you have to make sure each string for the file path has a space before.
then I ran into the problem where it would not open file paths that had a white space in the  whole path.
so after a bit of reading, I think because it's a shell operation? I have to have the string encapsulated in " " .
(please correct me if I am wrong on this)
so a simplified version below
import subprocess
fileSequenceList = [' "tmp/tmp/box.001.bgeo"', ' "tmp/tmp/box.002.bgeo"', ' "tmp/tmp/box.003.bgeo"']
subprocess.Popen(['gplay', fileSequenceList])
if I run into any other hurdles. il post them up.
cheers
Daniel
