radiating normals for curve having concave and convex shape
hello everyone
can someone be so kind to help me with this, i want the normals for the curve on right "U" to be radiating out... (the @P = @N; worked for the "O" which is a circle however it didn't work for something like "U") as in the redlines in the attached image.
thanks
m.
13 minutes ago, demoan666 said:
hi AntoineSfx,
thanks a ton for the reply, unfortunately that returned with the normals pointing in "y" direction i want them to spread out in "xz" direction.
m.
PS: unless of course i missed something.
Can you provide the hip file ?
Also, be aware that the vector you're looking for , after the wrangle I provide, is @tangentv, not @N.
Edited by AntoineSfx
21 hours ago, demoan666 said:
ofcourse!
NB: it's not the cleanest of files, as i was trying whatever i could.
font1.hiplc
enable [x] tangent Attribute   tangentu in node "resample2"
You can store the cross product in @N if you want, but by doing @N / @tangentu / @tangentv , you have a normal, orthogonal frame for each point, which is a strong foundation for anything downstream IMO.
Also see polyframe, which generates N, tangentu and tangentv. No need to do cross products by yourself
  • Like 2
  • 5 months later...
