Replacing Houdini Ground Plane In UE4
Snappy_Darko
17 hours ago, LaidlawFX said:
The groundplane dop allows you to point to a sop geometry. Make sure you look at the collision geometry though, as if the terrain is complex it may not reproduce it 100% with out adjusting the values.
Thanks, I used the Terrain Object node, which turned the terrain to a ground plane.. though my issue now is that I can't trigger the animation in UE4, they will be baked into the FBX and i don't believe can then be controlled by parameters in UE4 .
It depends on what is triggering the animation, as an example see the forum post below.
https://answers.unrealengine.com/questions/556925/animating-fbx-on-trigger.html
You may want to use the Texture Vertex Animation for something a bit more perform-ant. It's a shader that you will need to trigger though instead.
Thanks for the link.  The scene is first person and I want the animation to trigger when the first person gets within a certain distance from the object.  I'll try the texture vertex animation, Luis Kruel I think has a video on those.
