Multithreading
Omar Wanis
Hey Guys i have a workstation with a Xeon E5-2660 Processor (lots of cores but only 2.2 GHz per core)
How can i know what nodes are multi-threaded and what are single-threaded in Houdini? i wanna know where things start to get slow because of my cpu.
I tried to google it but didn't find sth really useful.
The progress from single thread to multithreading is still in progress.
Dynamic system and mantra are multitreaded(MT).
All Vex / vop's code is MT.
Under sops one part has MT other part hasn't. Every node that can be in a compiled block is MT.
Hope this helps a bit also what i have heard nodes that have MT will run the task on a single core when the data is to small.
2 hours ago, Omar Wanis said:
So basically, unless I'm doing heavy modeling, I'm fine with multicores with low Frequency, right?
Probably, since most modern CPUs use a higher boost frequency when only 1-2 threads are running. That being said, even the viewport display has highly multithreaded parts in it (generating normals, transfering data, convexing, etc).
