art3mis Posted August 25, 2018 Share Posted August 25, 2018 Hi Can anyone tell me if there is any difference between using the Lock Flag on a File SOP vs using a Stash SOP? Do they do the same thing (ie include any linked resources as part of the .hip)? Quote Link to comment Share on other sites More sharing options...
Luijee Posted August 30, 2018 Share Posted August 30, 2018 It works the same with a couple extras http://www.sidefx.com/docs/houdini/nodes/sop/stash.html Quote This node is conceptually very similar to locking a Null SOP, however it has several additional features: The interaction is slightly more convenient. You can modify or overwrite the cached geometry with hou.Geometry objects through scripting. You can link the geometry parameter to a parameter on a parent asset. This allows assets to inject geometry into a network without making the contents editable. The node never passes the input directly to the output, so Houdini doesn’t see downstream nodes as depending on upstream nodes. This is useful if a live connection would create a dependency cycle. Quote Link to comment Share on other sites More sharing options...
