CinnamonMetal Posted August 26, 2018 Share Posted August 26, 2018 Where can I find subdata records used in simulations ? Quote Link to comment Share on other sites More sharing options...
anim Posted August 26, 2018 Share Posted August 26, 2018 you can see them in your DOP network's Geometry Spreadsheet or import them as points using DOP Import Record SOP or access using dop expressions like dopfield() or Python Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted August 26, 2018 Author Share Posted August 26, 2018 1 hour ago, anim said: you can see them in your DOP network's Geometry Spreadsheet Within the Geometry folder of the DOP Network ? If so I'm looking in that area, I don't see any subdata records ? 1 hour ago, anim said: or import them as points using DOP Import Record SOP How do you know what Data Path & records you want to import ? 1 hour ago, anim said: or access using dop expressions like dopfield() or Python Similar question to the other two questions Quote Link to comment Share on other sites More sharing options...
anim Posted August 27, 2018 Share Posted August 27, 2018 when you look at the Geometry Spreadsheet while in Dop Network it will show you all the data of the Dopnet not just Geometry, it used to be called Details View (still named that way in docs http://www.sidefx.com/docs/houdini/dyno/about.html#detailsview), but then was unfortunately renamed to Geometry Spreadsheet that may seem confusing outside of SOPs so there you can see the path to all the data as it contains a tree view with all the info you need Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted August 27, 2018 Author Share Posted August 27, 2018 @anim I've searched within the Geometry Spreadsheet as well as read most of the page to which you linked. While in a DOP Network I'm searching, but I'm not finding the subdata records ? Quote Link to comment Share on other sites More sharing options...
anim Posted August 27, 2018 Share Posted August 27, 2018 which records exactly are you searching for? subdata records is a very vague term, you need to know what you need Geometry Spreadsheet tree view contains Objects and Data and nested data is called Subdata each of them has a name which can be custom, and they contain Records also different names like Basic, Options, Transform, Impacts, ... so without knowing what you are looking for it's difficult to help, looking for something specific? Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted August 27, 2018 Author Share Posted August 27, 2018 I understand how the tree view is laid out, and I see for example rbdpackedobject1 there is; basic, options, transforms & impacts. Is there not a list to see, or is it completely hidden ? I want to know if there is a list of these subdata records which can be exposed ? Or must I know exactly the attribute which is contained with the subdata records, but how can I know the exact name if I don't know what exists ? Quote Link to comment Share on other sites More sharing options...
anim Posted August 27, 2018 Share Posted August 27, 2018 you know what exists by looking at the tree of course you can probably even print it out using Python if you prefer, but it can be a lot of data Data can be arbitrary, each node may add it's own data, records, fields, that's why you have this view, to see what the sim contains, even what values if you want to just inspect. Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted August 27, 2018 Author Share Posted August 27, 2018 @anim What part of the tree, this part ? I see hexidemical data but nothing that pertains to attribute names ? Quote Link to comment Share on other sites More sharing options...
anim Posted August 27, 2018 Share Posted August 27, 2018 like this: examples of 1. sphere_object1 DOP object, Position data, Options record, displayed in Geometry Spreadsheet where you can see all the data fields in the record as well as imported to SOPs using DOP Import Records and shown in SOP level Geometry Spreadsheet as points with attributes that represent the fields 2. same principle, just showing sphere_object1 DOP object, Geometry/BulletData subdata, Options record Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted August 28, 2018 Author Share Posted August 28, 2018 I was able to access the position subdata once, and since that one time, I can't gain access to it as I'm having some difficulty re-gaining access to the Geometry ? I can locate the bullet subdata when inside a DOP network, rather then a AutoDOPNetwork considering there one in the same from what I know. Quote Link to comment Share on other sites More sharing options...
anim Posted August 28, 2018 Share Posted August 28, 2018 in your screenshot you are dealing with RBD Packed Object so in terms of Position you most probably want to fetch just Geometry (DOP Import, Dop Import Fields, DOP I/O or Object Merge SOPs can do that) since packed RBDs are represented as a single DOP object with Greometry containing packed primitives therefore RBD Packed Object doesn't have Position data directly as each point's P in Geometry represents the position and primitives intrinsic transform represents rotation and scale Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted August 28, 2018 Author Share Posted August 28, 2018 I assume when you say importing just Geometry in a DOP Import you mean; /obj/geo1/sim(DOP Network)/rbdpackedobject1/geometry ? What must you connect the import/output of either a DOP Import, or DOP I/O node ? When I mentioned I was able to access the position subdata only once, I meant without the use of any DOP Import, DOP Import Fields / DOP I/. I had selected a node whether within the DOP Network or the SOP Network and although I couldn't tell you as to what I did, as I only had done it once; I saw the position data, as well as some other subdata attributes, since then I can't recall how I found it ? Quote Link to comment Share on other sites More sharing options...
