Guest Posted September 13, 2018 Share Posted September 13, 2018 Hi all. I have a task which basically consists of building up a model from pieces lying as a junk pile. Imagine a car split into pieces on the ground, and pieces then starts flying up to their final position, gradually building up the model. But with the pieces interacting. So I have the model, and split it out on a ground plane, next step I imagine a particle setup. But does anyone have a ressource for such setup or any tips? Unfortunately I cannot share the model. Thank you very much in advance! :-) Quote Link to comment Share on other sites More sharing options...
habakuk Posted September 13, 2018 Share Posted September 13, 2018 (edited) would it be easier to do the whole thing in reverse? 1. break object in to pieces 2. let it fall apart and force it onto a pile 3. then reverse the cache? Edited September 13, 2018 by habakuk Quote Link to comment Share on other sites More sharing options...
Guest Posted September 13, 2018 Share Posted September 13, 2018 So it's already split into pieces. And I have to point jitter and explode view it to get it messed around. Then I sim it falling down, lying in a pile. And then I want it to sim it back up to the original model. Quote Link to comment Share on other sites More sharing options...
benne5 Posted September 13, 2018 Share Posted September 13, 2018 After you have done your simulation. Bring the data to SOP level using a DOP Import. Then use a timewarp node to reverse the cache. Input the range of the sim in the input range parameter and input the reverse in the output range parameter. It will then play in backward. Quote Link to comment Share on other sites More sharing options...
habakuk Posted September 14, 2018 Share Posted September 14, 2018 attached a super basic sample scene. hope this helps. reverse_rbd_fracture.hip Quote Link to comment Share on other sites More sharing options...
