Destruction in houdini (Help pls!)
guptaaa98
I was following this tutorial from pluralsight about architectural destruction in houdini and I am stuck at a part where I used a sphere to visualize a destruction of the building however instead of destroying the building pieces starts to fly diagonally upwards. I tried everything but cant come up with a solution. Please help. As far as I can tell the problem exists inside the geometry vop which is inside of dopnet which is inside of sim obj node. I will be highly obliged . Thanks@!
destruction.hip
